CUE and music.
jloviedo
FreeStyler Version: 4.1.6
CUE and music.
Post by jloviedo »
Within the CUE I have different timed sequences that cause a scene/sequence to be activated from time to time. If I press the Start button it does it correctly, but what I want is that when a song plays it does so automatically but I have no way of finding how to automate it. I've also been looking for that button within the shortcut and it's not there. Can you help me? Thank you.
(21.53 KiB) Not downloaded yet
KingThiq
FreeStyler Version: X2
Re: CUE and music.
Post by KingThiq »
Hey! I've been trying to do the same thing. I did a LOT of research, and finally figured out how to do it. There's a few forums about it, but here's the synopsis;
-Go to https://www.120db.uk/ and download FreestylerCommander. It will be a .rar file.
-Download WinRAR or something similar
-Use WinRAR to extract the files.
-Read the Instruction Manual.
If you download Multiplay from https://www.da-share.com/software/multiplay/ you can tell Multiplay to start your sequence as it starts playing a song. (See manual)
Additionally, there is a DJ addon that some people are using. I haven't explored that, but look in the "3rd party Addons and utilities" section to learn more.
FreeStyler Version: 4.01
Re: CUE and music.
Post by Partyman »
Using freestyler plugin with Virtual DJ will allow what you are looking for. There are many music software that can send midi triggers to Freestyler
