Backup freestyler ( another notebook )
FALCETTA
FreeStyler Version: 3.5.6
Post by FALCETTA »
good morning everyone, I need to install freestyler on another notebook as we need it for 2 separate events, (installed the same versions on both notebooks.) I tried to copy all the files, (fixture Chase cues etc. to the new PC, but I find that some moving heads perform color and gobo changes well, but the Pan and tilt movement does not work, they are always still for the movement in the creation of the cue I used the automatic shape of freestyler, how can I solve this problem?
perrip
Commited FS Forum helper
FreeStyler Version: 4.1.7
Re: Backup freestyler ( another notebook )
Post by perrip »
Freestyler has a backup restore option, that is how I do it. backup on your current set up and then restore it to the other PC. I find it is helpful to take the 6 other files that get created with the backup besides the main backup file. and put them in the same folder. should be pretty seamless, I think the backup restore option is Main files tab, but should only take a second to find it.
