Cue list problem
FALCETTA
- FreeStyler Version: 3.5.6
Cue list problem
good evening everyone, I'm having a problem with freestyler 3.6.37. basically I have 2 different cue lists (1 and 2) because I have more than 20 sequences, but if I change the cue list ( fast cue switcher) and switch to cuelist 1 and activate sequence 1 it happens that sequence 1 is also activated of cuelist 2, how can I solve it?
FALCETTA
- FreeStyler Version: 4.01
Re: Cue list problem
Not sure of the problem but you are using a far outdated version of freestyler. I understand you may choose not to update for various reasons but the problem you are having could be specific to that version of Freestyler. Although you may have to update your scene files it would be beneficial in many ways to update to the current release. Using the current version could fix your issue but could also get you more people trying to help you resolve your issue.
FALCETTA
thanks for the reply, I tried with 3 different versions of freestyler, 2 of the 3xx version and 1 also try with the latest version available today, but they all gave me the same defect, it's very simple to test it
