Lytequest Motorhead [SOLVED] Topic is solved
Dj Gforce
Post by Dj Gforce »
This is an old fixture, but still works quite well. I spent hours looking up the manual so I coul create a fixture, but the manual either doesn't supply the proper info, or I just have no idea what I am looking at.
Here is the manual http://www.geminidj.com/disc._prod_manu ... H-E697.pdf
Please help!
FreeStyler Version: N/A
Re: Lytequest Motorhead
Post by remco_k »
From that manual:
DMX Controlled Mode
Motorhead™ occupies five DMX channels:
1st channel - pan
2nd channel - tilt
3rd channel - color
4th channel - gobo
5th channel - dimmer
With this information you should be able to create your own fixture. (you'll need to try out wich values are wich colors (and gobos))
If you're ready, don't forget to post an exported pff file in this subforum: FreeStyler Fixture Files - User created Downloads
So no one else has to reinvent the wheel for the same fixture. :mrgreen:
rastafan2
Post by rastafan2 »
motorhead.
Motorhead.rar
(607 Bytes) Downloaded 107 times
