Use two RGB settings in one fixture
Magensa
Post by Magensa »
Dear all,
I was wondering if it is possible to use more than one RGB setting in a single fixture.
I am using an H807 DMX controller to control LED strips. The DMX adapter offers the selection of a first color by three DMX channels (RGB), which is working in fixture creator as well.
However, the controller also offers another set of RGB values, which are used for background colors (e.g. having a main color that moves through the strip as well as having a second color for the other LEDs not moving).
I did not find an option to add a second RGB setup into the fixture.
Is this possible somehow?
Thank you for the feedback and best regards,
Stefan
FreeStyler Version: 4.01
Re: Use two RGB settings in one fixture
Post by Partyman »
You can just create 2 fixtures and addresses them back to back
FreeStyler Version: 4.1.7
Post by Rod_Horning »
Partyman's suggestion should work. You could also investigate using the RGB segments feature.
