Rather simple question:
Why do the Bezier shapes stop moving when using a cue? Yes I do understand that when the cue would contain the pan and tilt of the fixture that is using the Bezier shape. But I really would like to use the Bezier shapes when playing other non Bezier shape related cues.
Why do the Bezier shapes stop moving when using cue?
magic
- FreeStyler Version: 4.1.6
- FreeStyler Version: 4.01
Re: Why do the Bezier shapes stop moving when using cue?
The bezier shapes are only designed to work within cues.
perrip
- Commited FS Forum helper
- FreeStyler Version: 4.6
Maybe if you had a separate cue that was running just the bezier shape you could run that over the non bezier shape related cue with the latest takes precedence idea
raphasicro
I have an opposite question.
After I leave an Override button, why does the animation of my moving heads - turned on in the Pan/Tilt Panel "ON", in one of the selected Bezier Shapes - turn off?
In other words, I have a Bezier Shapes turned on, movings are moving - I select an Override button - I uncheck the button to return to what they were before and the movings are stopped in their default positioning (configured by the Coordinate system).
In the Pan/Tilt Panel, the animation is shown as "On"! I need to click "On", it turns Off and click again to activate the Override button back.
How do I make going back and forth between an Override button stop a Bezier Shapes animation?
Thanks!
Thanks!
