MIDI CONNTROL - M-VAVE SMC-MIXER Topic is solved
raphasicro
FreeStyler Version: 4.1.6
I Use FreeStyler for: Church
Post by raphasicro »
Hello!
This is my first post.
I would like to know if the M-VAVE SMC-MIXER would work on freestyler.
As it is a midi controller, I thought about this possibility.
As I only found information related to audio programs, I'm not sure whether to buy it to test it or not.
Could you tell if it would work? I would use the faders to control colors or the equipment/group dimmer.
Thanks!
SiGNe
FreeStyler Version: 4.14
Re: MIDI CONNTROL - M-VAVE SMC-MIXER
Post by SiGNe »
Should work.
I have an Akai APC mini v2, that works too, even the faders.
Probably the hardest thing will be figuring out how to let the LED's on the controller to light up.
For the APC mini there are instructions on how to do that but with the M-Wave you might have to figure that out yourself.
