Hi, I have searched the forum and website but could not find a solution.
I have a fresh install of windows 7 because the hardware cannot handle newer windows.
I have connected Enttec OpenDMX
Installed Freestyler X2 4.1.6.
When I start Freestyler and the loading screen shows but it stops.
The progress bar does not go to 100%. Nothing is shown.
Nothing in the Eventlogs.
What do I check to find the issue?
Freestyler X2 loading screen....
jurrien
- FreeStyler Version: 4.1.6
- FreeStyler Version: 4.01
Re: Freestyler X2 loading screen....
Does any screen load?
Error boxes?
Error boxes?
C.T.E.
I think I have the same issue. The splash screen opens but that's as far as it goes, no errors, no progreess on the loading screen nothing.
Windows 10 pro (64bit)
Freestyler x2 v4.1.6
make sure you have .net 3.5 installed on the computer before freestyler install
