I wonder if you can help, I am currently using freestyler as has been described elswhere on this forum, so all of my movements are on submaster 1, colour chases and presets on 2, shutters on 3 etc, so that they can be mixed together to get a particular look in a "busking" fashion.
My question is this, I'd like to have my shutter chases/settings set up so that some of them are pre-programmed speed, some are sound reactive. However, as the submaster cue is changed it replaces the one in the cue list but does not modify the sound reactivity option or loop settings etc. is it possible to makethese settings record with the specific sequences in the cue list?
Does that make sense?
Also, I have been having a play with the new version 3.0 and it looks like there are some useful new features, I am used to the Avolites pearl so it is nice to see some simialr functionality appearing
A couple of questions though :
- FX generator
- is it possible to modify how any steps are recorded in the chase, in order to get smoother movement / faster speed?
- Can the effects be applied to other channels, i.e. the CMY channels to create rainbow effects?
- Shape Generator
- I cant seem to get the shape generator to operate (admittedly I don't have access to my rig at the mo so I am only baseing this on screen view) but I choose a shape and click "on" but the little dot does not move, am I missing something
- Finally as an alternative/enhancement to the fx engine that has been added, it would be wonderful if the "even distribution across fixtures" functionality could be added to the shape generator, a bit like the pearl. So that all fixtures follow the nice smooth shapes of the bezier, but perform the wave like the fx engine. Perhaps even more options that allow fixtures to move in pairs/3s/4s or evenly distributed... I think I am moving into wish list territory now!
Anyway, any help would be much appreciated if anyone has any ideas?
Kind Regards
Ben
