Glitchy fixtures!!
Tadelis06
Glitchy fixtures!!
Post by Tadelis06 »
Hello guys, i have problem with freestyler. It all working properly on my laptop. But i wanna connect my lights on another laptop and all chanels won’t work properly. I have connected ledpar fixture. And colours won’t light up linearly like it should have. Starts glitching about have way up. I tried different versions, latest and same as on another laptop. Fixture profiles are the same. I also tried on two more pc’s. And it’s the same problem. Maybe anybody had same? I’ll attach example
54010630-2154-4405-ABB7-26FA4E040E50.MOV
(812.75 KiB) Downloaded 23 times
FreeStyler Version: 4.1.7
Re: Glitchy fixtures!!
Post by Rod_Horning »
Are you using the same interface?
Try setting the priority of Freestyler higher. This is selected in Setup, extra options:
