Good morning, I tried to install the latest version of freestyler on another PC, I copied all the fixtures I created and imported all the scenes and various cues, but unfortunately they don't work, is there any procedure to move to the next version?
Is it possible or do I have to do it all over again?
MOVING TO LATEST VERSION
FALCETTA
- FreeStyler Version: 3.5.6
- djSupport
Re: MOVING TO LATEST VERSION
You shouldn't need to do anything other than install the next version over the old, you should backup your files first though I guess incase of a problem
