Need a profile for MHBEAM60-FX
skykid
FreeStyler Version: x2
Post by skykid »
Hello. I have looked everywhere but can`t find profile for MHBEAM60-FX :
Manufacturer: Ibiza Light
Standard Lamp: LED
Voltage: 100-240 V/50-60 Hz
Wattage: 80 W
Beam: 8°
Light Source: 2 x 30W RGBW LEDs and 2 x 12 5050 RGB LED
Closest I got was a https://www.crescit.com/a.fixture_dmx.p ... 0wMVVRVDA9 that profile and I failed measurably trying to use it at fixture creator could anyone help me ?
ibiza_MHBEAM60FX_manual.pdf
(2.49 MiB) Downloaded 45 times
skykid
Re: Need a profile for MHBEAM60-FX
Post by skykid »
At the end I ended up buying the fixture and am sharing it with the community
ET.pff
(96.83 KiB) Downloaded 26 times
Where did you buy it?
