Training Required
villeric
Just started using FS
FreeStyler Version: 3
Instagram: villeric
Training Required
Post by villeric »
Hello group,
I want to learn how to create the 3 fixtures I bought :) But it sounds chinese to me to do it by myself.
Would someone in the group would be willing to assist me by Messenger or Teams or other.
I can share my screen and you help my step by step and at the second one you'll see if i understood properly :)
If not, I'll try it and share my tries with you to help me to correct my mistake =-)
Thanks a lot
Re: Training Required
Look at the wiki it has step by step guides
perrip
Commited FS Forum helper
FreeStyler Version: 4.1.7
Post by perrip »
What I have found helpful is to find a similar fixture, and then just modify the fixture profile to match the fixture you have.
