Hi, a simple USB to RS23 standard converter (COM port), then adapted physically to 485, is ok for DMX protocol? How the serial interface should be configured? Speed, parity, stop bit..
How to use the COM port in Freestyler?
thank you
Possible to use a simply USB to 485 serial adapter?
GiovanniG
- remco_k
- FreeStyler Version: N/A
Re: Possible to use a simply USB to 485 serial adapter?
Lets keep it with one topic, shall we?
Is DMX compatible with RS232
