Quelist problem Topic is solved
Jevm
Quelist problem
Dear Members, I'm already working with freestyler to control my lights, but I have a problem, I can create ques but I can't open my quelist in any way. Normally this opens under the play icon in the toolbar, right? so this doesn't work. At first it worked, now suddenly it doesn't. If anyone knows a solution, I'd love to hear it.
- FreeStyler Version: 4.01
Re: Quelist problem
you must load list into the cuelist area. Please explain your steps
- djSupport
Re: Quelist problem
Under one of the menus you'll see an option to reset window positions this will make it reapear
Jevm
Re: Quelist problem
Dear DJ Support,djSupport wrote: 15 Jun 2023, 08:08 Under one of the menus you'll see an option to reset window positions this will make it reapear
thank you very much for your answer it works again, I'm happy, I also have another question, you have different loop lights and shutter effects in the fx generator, can you also adjust them in speed? Greetings Jevm
- djSupport
Re: Quelist problem
Unfortunately I don't know the answer to that one sorry
Re: Quelist problem
Speed is determined by the times between step in the sequence creator. Whatever you program into sequence creator will affect all steps created by FX
Jevm
Re: Quelist problem
Dear, I succeeded, thank you very much for your answers, greetings jevm
- djSupport
Re: Quelist problem
Good to hear
