Hi
Im trying donwload old version freestyler with no luck,
ERROR:
DokuWiki Setup Error
The olddir ('attic') at /var/www/vhosts/thedmxwiki.com/httpdocs/data/attic is not found, isn't accessible or writable. You should check your config and permission settings. Or maybe you want to run the installer?
I want to use nanopad so only one its working seems version 3.5.2 or older.
anyone have version similiar ?
Regards
Old Version Freestyler
Papas-Tuga
- FreeStyler Version: v.3.5.2
- Instagram: brunosousadj
