Hello light people!
I'm a begginer with freestyler and after hours searching to solve this (how?) basic problem, I'm still unable to use two rgb moving heads (same direction, one left and one right, kinda speakers) to work together at all.
In "demo" mode (master-slave) with a dmx link and a pan reverse on the slave unit, the "twin concept" is well here, but software side and at first, the "clone fixture" function doesn't seem to work (nore s2l or manual pan). I'd just updated to 4.6.1 without more success.
I must have missed a detail but wich one?
I also wish to fix a "180°" pan limit and a 90° tilt "line" to this pair of moving heads to use it on my cap. But I don't know If there is a way to "constrain the group clock" about moving field...
Fixture pan "polar" twinning
Dblab
- Just started using FS
- FreeStyler Version: 4.1.6
Dblab
Re: Fixture pan "polar" twinning
I finally got the cloned fixture to react by setting the S2l and the manual pan too...
The problem is now to the moving field question.
Dblab
And s2l is doing it too! solved
