Freestyler with Virtual DJ 2023 Performance Pad lighting
Laszlo
FreeStyler Version: 3.6.49
Twitter: -
Instagram: -
Post by Laszlo »
Hi all,
I have connected Freestyler system with VDJ 2023 pro. Light effect works fine but the pads don't light up in the VDJ nor on my controllers. When I press a button, I don't have any visual feedback. The pads do not illuminate. So I don't know which light effect is currently active.
(If only VDJ is open and Freestyler is not, then the PADs will be lit. But if both programs are running, they no longer light up.)
Does anyone know how should I program the pads? What script do I need and where should I enter it?
Many thanks for the help!
