Hi
I am having troubles programming a sequence using freestyler.
My process is.
1. Select fixtures which will be programmed by the sequence.
2. Open Create Sequence
3. Set Values, whatever they maybe (for example on one fixture I am setting two dmx values, one another 2 fixtuers I would like a bezier shape running).
4. Insert Cue point.
5. Save Sequence.
6. Drag saved sequence to cue list.
When I press play on the sequence, the actions that I though I saved in the cue editor don't action. Or they action for a second or two and then then lights go dark and nothing happens.
Manually adding dmx values via freestyler works fine, and so does bezier shapes. I want to program my lightshow to only do a few simple things, but I am finding it tough with freestyler.
Appreciate any help, I have followed the steps on the wiki and I am still getting nowhere.
Problem with programming sequences
cjjb86
- FreeStyler Version: 4.1.6
- djSupport
Re: Problem with programming sequences
You 'insert cue point' do you mean you created another 'scene'? A scene is like animation frames, you have an option to 'snap' or 'fade' or 'off' between scenes when programming if you save your first even with the light on and it's set to snap on the second scene it will turn it off again if nothing is set, as fast as you have set it, if it's set to 'off' on the second scene the value will remain unchanged and not turn off if it's set to fade it'll fade the values for example it you set the dimmer to full and the next value to 0 it won't simply turn off it will fade down at the speed you've set when programming etc check the wiki for a full walkthrough guide to programming
- FreeStyler Version: 4.01
Also when you open a new sequence you are on step 1. Just adjust the channels that you want on and turn on the bezier and save. there is no need to add a step unless you want different actions to happen within that scene. Basically just remove step 4 in your description
- FreeStyler Version: 4.1.7
In the sequence creation window click on options (lower left hand corner). If "clear channel values when closed" is selected try un-selecting this option, saving the sequence and test.
patmsrd
- Just started using FS
J' ai exactement le même problème. Me concernant, ceci ne viens pas des drapeaux qui modifie ou pas la valeur d' un canal a la scène suivante. Je connais le principe de ces drapeaux et ce n' est pas la cause. Je viens de poster un message sur le forum a ce sujet . Impossible pour l' instant pour moi d' enregistrer un séquence conforme a ce que je réalise avec l' éditeur de séquence. 9 fois sur 10 la séquence n' est pas enregistrée correctement. FS est inutilisable en l' état et nous sommes plusieurs sur le forum a avoir ce problème d' enregistrement de séquence. (W11F + FS 4.1.7 + EUROLITE DMX512 MKII) . Merci de nous aider ou de corriger ce bug
I sent you a Private Message about your submaster issue
In the CUE list make sure the up arrow pointing to the left is grayed out.
Also, in the SEQ make sure the option "Restore values when sequence stops" is NOT checked.
I also make sure the SEQ is not set to loop (unless that is what you really want).
patmsrd
J' ai bien reçu votre message personnel . Le problème est en amont de cela. Lorsque l' on enregistre une séquence, elle n' est pas enregistrée correctement.Lorsque que l' on sort de la fenêtre d' édition de séquence et que l' on re-ouvre la séquence que l' on viens d' enregistrer, les valeurs des canaux et les drapeaux sont différents de ce que l' on viens d' enregistrer. Les séquences dans la liste des cues et des submasters ne font qu' exécuter des séquences dont l' enregistrement est erroné - (W11F + FS 4.1.7 + EUROLITE DMX512 MKII) . Merci de nous aider ou de corriger ce bug.
Veuillez utiliser Bug Tracker pour documenter et soumettre le problème. C'est ici que le développeur Freestyler est informé des erreurs et des problèmes.
