When creating the sequence, I can e.g. do not set different colors for two par LEDs. After I get the second par LED, the first one is switched off.
In Version 4.1.1 that was no problem. Is there a new setting for it?
Create sequence - lose setting Topic is solved
maxmaxmax82
- FreeStyler Version: 4.1.5
xlbeat
- Just started using FS
Re: Create sequence
Happens to me exactly the same.
Same goes for moving heads. After you choose other fixture, the first one loses his settings.
maxmaxmax82
Re: Create sequence
Which version are you using?
could it be a bug in version 4.1.5?
- Spirit
- FreeStyler Version: 3.5.9
Re: Create sequence - lose setting
Yes this is a bug with 4.1.5 and its already reported
4.1.4 doesnt have this but it has other related issues.
but i would use 4.1.4
- djSupport
Fixed in 4.1.6 now downloadable from main forum page
maxmaxmax82
Thank you!
