PURElight LED BAR 18 18x 3W RGB
Kiter1988
FreeStyler Version: latest
Post by Kiter1988 »
Hi everybody,
can anyone create a fixture of this lightbar ?
I'd like to have the 13 channel mode.
I have only the german manual but i translate it.
Channel: Value: Function:
1 - 000-255 1. Segment red dim 0-100%
2 - 000-255 1. Segment green dim 0-100%
3 - 000-255 1. Segment blue dim 0-100%
4 - 000-255 2. Segment red dim 0-100%
5 - 000-255 2. Segment green dim 0-100%
6 - 000-255 2. Segment blue dim 0-100%
7 - 000-255 3. Segment red dim 0-100%
8 - 000-255 3. Segment green dim 0-100%
9 - 000-255 3. Segment blue dim 0-100%
10 nothing
11 - 000-255 Strobe (slow to fast)
12 - 000-009 manual dimm
.............010-249 integrated effects
.............250-255 sound to light
13 - 000-255 effect speed (slow to fast)
FreeStyler Version: 4.1.7
Re: PURElight LED BAR 18 18x 3W RGB
Post by Rod_Horning »
Your profile indicates you are running a rather old version of Freestyler (version 3.4.6).
Before I build the fixture I suggest you consider moving to a newer version of Freestyler - 3.6.4?.
Kiter1988
Post by Kiter1988 »
Rod_Horning wrote: 05 Mar 2023, 02:05 Your profile indicates you are running a rather old version of Freestyler (version 3.4.6).
Sorry, thats an old entry, i change it. I use the latest version
Attached is my attempt at a fixture for your instrument.
Your request lists channel 10 as doing nothing. Channel 12 is listed as dimmer/effect/sound_to_light. The dimming range is only 0 thru 9 which, to me, indicates this is not a dimming range but rather a range that selects manual dimming which would be controlled by another channel. I took the liberty of setting channel 10 as the actual dimming channel and included a macro that will set channel 12 to 0 and a macro that will set channel 12 to sound to light.
The effects and effects speed have custom sliders defined.
The red, green, blue LEDs (3 sets) are controlled with Freestyler's segment feature. To select the segment or segments click on the desired segment check box in the color palate window.
After adding your fixture to the Freestyler workspace, select it, click WINDOW in the menu bar and then click All This opens several windows which will help ease your programming chore.
Your feedback is most welcome.
UPDATE: I just found an English version of the manual. Indeed it says NO FUNCTION for Channel 10. I can change the fixture but I would like you to test it first to confirm that C10 actually has no function.
PURElight_LEDBAR_18.pff
(16.74 KiB) Downloaded 33 times
