Moving between fixtures auto reset of all DMX values of the previus selected fixture
ginof40
FreeStyler Version: 4.1.1
Post by ginof40 »
Hello!
i'm pretty desperate. After re-installing freestyler on a notebook (using open Enttec, but i don't think the problem is here) my old stage did't work anymore (crash of freestyler at start).
I created a new stage using same fixtures and i have this problem:
both in "create sequence mode" and in simple stage in real lights and on 3d Easyview if i set some values in fixture (for example dimmer set on 255, red set on 150 etc) when i click on another fixture the previous auto set all DMX to 0.
:( :( :( :( :( What happen?
thank !
ginof40
Re: Moving between fixtures auto reset of all DMX values of the previus selected fixture
Post by ginof40 »
ok, i'm not sure but i think is a bug. For the moment i solved unistalling 4.1.15 and installing 4.1.1 and now it works!!!
xlbeat
Just started using FS
Post by xlbeat »
Same here
SiGNe
FreeStyler Version: 4.14
Post by SiGNe »
Here also, i have that since 4.1.5
Luckily i only need the fader but as soon a i click on a lamp or a group all settings reset to zero.
And with the freestyler app the fade in adjusts length from the fade from 1000ms to 2000ms and more if i keep tapping fade in.
That problem started with 4.1.4
FreeStyler Version: 4.1.7
Post by Rod_Horning »
Please report this in the BugTracker/FeatureRequest system. Click on QuickLinks at the top of the page for the link. If you have not as yet set up a user id in that system you will need to do so as the bug tracker system is separate from this forum.
this is a known issue and will be fixed. use 4.1.4 instead
SiGNe
Post by SiGNe »
4.1.6. solved all my problems, great work!
