Unable to add machines in Freestyler 4.1.5
kheops
FreeStyler Version: 4.1.1
Post by kheops »
Hello,
Since the latest versions of Freestyler, it is impossible for me to add machines!
(on the other hand, I can always remove some).
I have to go back to version 4.1.1 for it to work again!
I am on windows11.
Does anyone know where this problem comes from?
Thank you in advance for your help
Re: Unable to add machines in Freestyler 4.1.5
Please report on bug tracker, link is in above menu
kheops
Post by kheops »
I don't know why, but when I try to log into the bugtraker it tells me that my account may be disabled or that I didn't use the correct username or password! However, I manage to connect to the forum!? I don't understand
kheops
Post by kheops »
You need a different account on bug tracker, it doesn't work with the forum
kheops
Post by kheops »
Ah, sorry, I didn't know.
It's done now.
THANKS!
I saw cheers,
