Has anyone a Fixture for the "eurolite LED PIX-144 RGB Bar" with least 12 Channels?
techno_creator
- FreeStyler Version: 4.1.1
Everyone I create by my self has any errors. In 3,5 and 6 Channel mode it works but in 12,24 and 84 it doesn´t.
- FreeStyler Version: 4.1.7
Re: Has anyone a Fixture for the "eurolite LED PIX-144 RGB Bar" with least 12 Channels?
Try changing the way you think about your instrument. It actually is 8 instruments physically packaged as 1.
Set your instrument to 48 channel mode.
Add 8 of the 6 channel fixture definitions to the Freestyler workspace. If you add them all at once Freestyler should correctly increment the starting DMX channel number.
If you add them 1 at a time be sure to correctly set the DMX addresses. The 1st one you add must have a starting address the same as you configured the physical instrument. The 2nd one's starting address would be 6 higher, the 3rd would be 12 higher than the 1st (6 higher than the second) and so on.
If you prefer the 24 channel mode then you would add only 4 of the 6 channel definitions.
techno_creator
Thank you very much, but is there possibility to say in Freestyler Fixture A, take your colours from Fixture B?
Assuming that fixture A and fixture B are part of the PIX-144, select both and both will display the color that you choose.
techno_creator
But if I want to use SoundToLight all segments are doing something else?
I am not aware of a way to do that but I do not use SoundToLIght so am not very familiar with the functionality.
Perhaps another user can provide input.
