Couple touchscreen pages to midi pages
PeterJack1975
FreeStyler Version: 4.1.1
I Use FreeStyler for: Band
Post by PeterJack1975 »
Hi All,
My first post here after playing arounbd with Freestylers fore the past years.
I've always used a laptop with an APC mini as controller and this worked pretty ok.
Now i've bought a touchscreen and am creating a touchscreenpage that maches both my setup as well as the layout i use on de APC mini.
The mini uses 4 pages (and a shift-page as well).
1. Sequence control
2. Color control
3. Position control
4. Dimmer/Misc control
On the touchscreen i've made similar pages since that's the way i'm used to work and as a sound-engineer i dont have time to learn new tricks.
Would it somehow be possible to couple the touchscreen and midi pages?
I can use a touchscreenbutton to change midi-pages, but it wont switch the touchscreen in the same action and i can use a midi-button to change the touchscreenpage, but not the midi-page as the same time.
I've played with the idea to use a tool to map the midi-command for "midi page x" to 2 midi-commands, also resulting in "touchscreen page x". This could work, but i would prefer to have the APC follow the screen.
Any bright ideas?
Or maybe i've missed a feature ;-)
Thanks!
