Does anyone have any fixtures for lights, Shehds moving head 100w GOBO please? I'm a beginner and honestly can't do it myself.
So I'm asking for help, I'll be very happy for advice and a download link.
Thank you guys.
HELP, Shehds moving head 100w GOBO
Pekos
- FreeStyler Version: 3.6.51
- Instagram: DJPekos
- FreeStyler Version: 4.1.7
Re: HELP, Shehds moving head 100w GOBO
Is this your instrument?
https://www.shehds.com/collections/led- ... _gQAvD_BwE
In order to help you we will need the DMX channel assignments. Please provide a link (or upload) to the user manual (English preferred).
Pekos
It is exactly this type.
https://www.shehds.com/products/6-prism ... ghting-617
I am sending the user manual in the attachment.
Thank you
Thank you
100W图案灯-6棱镜定制版-不带光圈版.pdf- (719.57 KiB) Downloaded 187 times
Thank you for the links. Attached is a fixture file that should work with your instrument.
NOTE: Gobo pictures and DMX values need changed to the actual values and pictures. The user manual has the pictures but not the values.
NOTE: Same note for the COLOR wheel
Until the fixture file is updated with the correct DMX values and pictures, the GOBO windows and COLOR WHEEL window will not be helpful in programming.
Your feedback is most welcome.
SHEHDS_LED SPOT 100W.pff- (59.38 KiB) Downloaded 227 times
Pekos
Great, thank you very much. You are amazing! As soon as I find the user manual, I will immediately forward it for addition.
Huge thanks!
Huge thanks!
djarmandomoura
- FreeStyler Version: 4.1.6
I need the fixture
Pekos
Hello,
How can I insert a file into 3D easy view?
