Hello having trouble completing this fixture profile
Shehds led 150. Everything works fine except the pan and tilt, not sure what im doing wrong.
ill attached the file i created. and will paste the manual.
https://drive.google.com/file/d/1OaCHAA ... njNSc/view
SHEHDS LED 150 ** PAN AND TIlt doesnt work correctly.
erico
- Just started using FS
- FreeStyler Version: 3.4.8
LED 150 SHEHDS.pff- (166.58 KiB) Downloaded 28 times
guffyz
Re: SHEHDS LED 150 ** PAN AND TIlt doesnt work correctly.
Bonjour,
pan 8bit =3
tilt 8bit = 5
pan range =4
tilt range =6
rien sur 16 bit
à tester
pan 8bit =3
tilt 8bit = 5
pan range =4
tilt range =6
rien sur 16 bit
à tester
erico
Thank You SO Much
ernescm
I have a question, the tilt is 190 or 270, it seems to me that the lens does 270
ernescm
ok, yesterday receive 4 led 150 and confirmed the tilt is 270!!
