I have a Colorsplash 196 and can't create it! It has 7 channels - all 7 of which are rgb control.
1 - red 0-100%
2 - green 0-100%
3 - blue 0-100%
4 - red 0-100%
5 - green 0-100%
6 - blue 0-100%
7 - red 0-100%
I can't figure out how to create this fixture. I have even tried to cheat and create two fixtures, but this doesn't seem to work either.
Please help! Thanks.
Request/Question - Chauvet Colorsplash 196 Topic is solved
aquas
Re: Request/Question - Chauvet Colorsplash 196
in the manual said that? beacause it's impossible use 3 channels Red and only 2 Green/Blue. the first or the last channel normaly is a shuter/intensity/pré-Prog channel... try to teste creating a dimmer pack with 7 channels...and test one next another.
Or you have more than 7 channels, it means that you can test creating a max of channels (33), and see what channels do in your fixture.
Set your fixture to the channel 1, create a dimmer pack with 33 channels, set it to the first channel, move the sliders on the rigth one by one to see.
cumpr
cumpr
- remco_k
- FreeStyler Version: N/A
Well its weird but actually it is correct, those 7 channels.aquas wrote:in the manual said that? beacause it's impossible use 3 channels Red and only 2 Green/Blue. the first or the last channel normaly is a shuter/intensity/pré-Prog channel... try to teste creating a dimmer pack with 7 channels...and test one next another.
cumpr
At least, according to this manual: http://www.chauvetlighting.com/products ... ug-126.pdf
bendigo, you need to create a 7 channel parcan/dimmer in the fixture creator. And ofcourse, when it works, you post it here. Right?
aspen20
ColorSplash 196.pff- Chauvet Colorsplash 196
- (35.06 KiB) Downloaded 53 times
