Looking for small DMX player / recorder Topic is solved
erwinredl
FreeStyler Version: 4.1.4
Post by erwinredl »
Hi there,
I am looking for small DMX player/recorder, preferably just a circuit board with screw terminals, and no housing. In the past I've used the Chauvet DJ DMX-RT and removed the housing but the quality of that product declined dramatically to a point where it is rendered useless. Same with NicolAudie products, too expensive for my application, very buggy software, and unreliable hardware for professional use.
I've looked into the Enttec S-Play SP1-1 70092 but it is simply too big and expensive for my application. Raspberry PI, etc. would also be too big and bloated for my very, very basic needs.
I've found 2 products on DMX4all.de in Germany, the DMX-Player XS and the DMX-Player L-MK2, but just the shipping is $70+.
Application:
- Program light sequences created with the ETC Mosaic MSC / Mosaic Designer 2 software / hardware (my favorite DMX toy but too big and too expensive for my application)
- Record DMX/ArtNet/or similar light sequences from ETC device to small DMX player/recorder hardware
- Play the light sequences back as DMX data on start-up of small DMX player/recorder
No calendar function or reordering of sequences needed, just the most basic record and looped playback.
Any recommendations?
Thank you for your help in advance!
Erwin
Re: Looking for small DMX player / recorder
Martin did a playback control, I'm not at a computer to check but you'll see the option to upload to it in FreeStyler, might be able to pick up an old one as the last time I saw one was approx 20 years ago!
erwinredl
Post by erwinredl »
Thx!
Erwin
Return to “DMX Interfaces”
