Chauvet Wash FX HEX
erico
Just started using FS
FreeStyler Version: 3.4.8
Chauvet Wash FX HEX
Post by erico »
Hello im trying to create the 11 channel profile for this light.
Everything works fine with what I created Use the channels manually.
Where im stuck is making the macros, Im fumbling in this area.
Or getting the pallets to show.
Here is the manual: 11Channel (Would love the 40 channel profile, )
https://www.chauvetdj.com/wp-content/up ... 6_Rev1.pdf
And here is the profile.
Chauvet_Wash Fx Hex.pff
11 channel
(6.12 KiB) Downloaded 27 times
FreeStyler Version: 4.1.7
Re: Chauvet Wash FX HEX
Post by Rod_Horning »
Hello
Just my opinion. In order to easily use the 40 channel mode I think you will need to create 2 fixture profiles. One profile (lets call it MASTER) will control channels 1, 2, 3, and 4. The other fixture profile (lets call it ZONE) will control the zones.
Add 1 MASTER to the Freestyler workspace.
Add 6 ZONEs to the Freestyler workspace.
The MASTER starting DMX address must be the same as the DMX address you configure in the instrument.
The 1st ZONE starting DMX address must be 4 higher than the MASTER.
The 2nd ZONE starting DMX address must be 10 higher than the MASTER. (6 higher than the 1st ZONE)
The 3rd ZONE starting DMX address must be 16 higher than the MASTER. (6 higher than the 2nd ZONE)
The 4th ZONE ...
The 5th ZONE ...
The 6th ZONE ...
I suggest that the fixture names and pictures show the relationship and that you group the fixtures on the Freestyler workspace so that it is clear they are related (ie. the same instrument).
erico
Post by erico »
I see can ya help create the 11 channel 1 then. Thanks
I am sorry for the very long delay responding to you. I have not been active here for some time.
Do you still need the fixture created?
