Urgent please: "Input Past End Of File" what does it mean?
GiovanniG
Post by GiovanniG »
Hi, Loading a sequence doesn't give this popup, works ok, if I add the same sequence to the cue list, when I toggle the cue lists I have always this. The effect won't run until I press ok, how can I fix it? What doest it means? Where the problem is? Is it a problem into the fixture file?
I'm a bit aftraid for the new year eve, I hope you can reply me, thank you
FreeStyler Version: 4.01
Re: Urgent please: "Input Past End Of File" what does it mean?
Post by Partyman »
open the fixture file then try to save it. When you try to save it will show you the problem so you can fix (usually some wrong value under animation wheel)
GiovanniG
Post by GiovanniG »
thanks for help, the problem disappeared after update to 4.1.4, does it has sense?
It'll be a bug that was fixed, however it's usually a corrupt file
