Hi everyone. I've searched the forum, and I'm not finding alot about the CHS file extension. When I modify an old program/scene, and save it, it is saving it with a .chb.chs extension. I thought the chs file extension was a "chase" scene, but I think I'm wrong. I'm using V4.1.1.
I found that after making a change and saving it, when I would run the program, the change wasn't saved, and the program seemed unaffected. After digging deeper, the file WAS saved with the same exact name, and chb.chs file extension. Is that what it's supposed to be doing?
TIA
CHS File Extension
Tibby
- FreeStyler Version: 3.6.3
- I Use FreeStyler for: Band
- djSupport
Re: CHS File Extension
In the name box, clear it and write in a new name and save it, does this fix it? If not I suggest leaving a report on the bug tracker
