fixtures with master dimmer % visible
ayoungman
I've just created a fixture profile for some LEDJ light battens. They work just fine. On the screen it displays the dimmer value as a % and the fixture also reacts to the master dimmer control button. I've tried to create LED fixtures before to react to the master control but have not had any success. I cannot see any diffrence between the fixture files so what have I done differently this time ?
- FreeStyler Version: 4.01
Re: fixtures with master dimmer % visible
For the Master Dimmer to work you have to have an intensity channel (not just a dimmer channel).
Rusty
Rusty
ayoungman
I've sorted it. The LED parcan picture i had chosen had a white backround so I couldn't see the %value ! I changed this and made sure each fixture would react to master control. All 24 LED Parcans now fade up slowly ! Lovely jubbly !
