First up hello. Its been a long time since i posted on here. I used to be quite prolithic and Ive been using FS for well over a decade so theres not much I don't know about it. But we all find issues sometimes so here goes . . .
Im looking for a way to do this and I think I found the only answer but someone may have a better way ?
I have some baic RGB fixtures which have no stobe channel in the profile.
SO I made a 2 step sequence - step one all on - step two all off and set the speed to max in the sequence creator. Still not fast enough for a 'strobe effect' but in the submaster or cue list if i ramp the speed up to 500% it does look like a strobe effect. WINNER!
Now the problem. When controlling I use a custom iPad app and for all strobe features i use on other fixtures I have an override button set to flash mapped to my app, that works like a charm. However in this case i cant do that. Instead I would have to create a second sequence in the sub or cue list that sets the fixture to be just off (all values at zero for that fixture). Now this does work but its not exactly convenient if you wanted to have a quick burst of strobing.
For clarity on the type of fixture, Im using some WS2811 RGB pixel chips being controlled by an Enttec DIN pixie controller to convert them to DMX control. This is all in a custom built giant LOVE sign. Anyway I digress.
So in essence if i could have a 2 step override button that allowed additional speed control, set to flash, my problem would be solved. I know this is not currently possible and probably never will be.
So does anyone have a work around they can think up ? Maybe some scripting ideas ?
TIA !
Lee
Virtual strobe for basic RGB LED fixtures
- dmxlighting
- FreeStyler Version: beta
- dmxlighting
Re: Virtual strobe for basic RGB LED fixtures
In case anyone was interested i found a resolution to my problem.
Ive scrapped the Enttec Din Pixie device and replaced it with a Jun Pro DMX to SPI controller.
These units have a better personallity which will do a strobe effect along with some other clever sequencing effects on most pixel chip LED's (WS2811 etc). It will not give individual pixel control like the DIN Pixie but it makes up for that in many other ways. Unit can be purchased directly from Malaysia via Ebay for about £155 including shipping. Not cheap but after a bit of research its the best DMX to SPI device ive found so far.
Ordered on Friday and was delivered today (less than a week from Malaysia is pretty go i think!)
DMX profile personality is 13 channels and each device can run 1024 pixels. Devices and be daisy chained together.
Youtube video here for reference - https://www.youtube.com/watch?v=YX2qg3LpXXw
