Hello, when I start freestyler I Have an error : "Error Loading Cue Data. Do you want to load default values". It appears when i try to save the location too.
I would like to investigate for fixing this problem but I don't know where.
Is there some log files where I could see what is the problem ?
Thanks, Jérôme
- FreeStyler Version: 4.1
- FreeStyler Version: 4.01
Re: Error Loading Cue Data
Usually caused by having link to a cue in a location (override buttons, cue window, submaster) but the actual file it triggers has been removed, renamed, or altered. Easiest solution is to launch freestyler then trigger any and every cue that you have loaded into a location. When the error pops up you will know what file is causing the error. You could also create a new location and just reload everything.
Thank you, I will try it.
I've tried to start from scratch. I know now where is the problem : it appears when I have more than 1 page of cuelist buttons. I've reported a bug for this version 4.1.2beta. Thank you for your help.
