Master Intensity Issue - Chauvet Barrel 300
ajp8868
FreeStyler Version: 3.4.6
Post by ajp8868 »
Hi All,
Seem to be having an issue with the master intensity but I'm not sure if it's an issue with the fixture file or the software..
So, the fixture reacts as normal until the intensity hits 0, when it suddenly goes back to full brightness while all other fixtures are off as they should be.
Looking at the manual here: https://www.chauvetdj.com/wp-content/up ... WOlogo.pdf, it indicates that the intensity channel is just 0-100% so I don't know what's happening..
Any Ideas?
fixture file attached
Intimidator Barrel Led 300 11 Channel.zip
(1.02 KiB) Downloaded 19 times
FreeStyler Version: 4.01
Re: Master Intensity Issue - Chauvet Barrel 300
Post by Partyman »
I see a couple problems that may be the cause. Try this profile and see if everything works ok, I have a couple of those fixtures
Chauvet_Intimidator_Scan_Led_300_11Ch.pff
(226.4 KiB) Downloaded 22 times
ajp8868
Post by ajp8868 »
Hi Partyman, thanks for that. Haven't had chance to test yet but I'll let you know as soon as I have.
Can I ask what was changed - so I can tell in future?
ajp8868
Post by ajp8868 »
Ah, just reinstalled the fixture and it's the Scan version you've edited - I've got the Barrel which may be different?
Post by Partyman »
profiles are identical
