3 dimmers + a strobe chanel
Schuim
FreeStyler Version: lates
Post by Schuim »
So I got my hands on a fixture which creating it in FS boggles my head because it might have an sort exotic function.
Its a 1-4 channel device where I need 3 dimmers + an strobe channel.
How would you create a fixture like this in FS?
Ch1: left eye 1-100%
Ch2: right eye 1-100%
Ch3: both eye's 1-100%
Ch4: strobe 6-123 (slow till fast)
The fixture is the:
Acme Eyeflash 2 WW
https://en.acme.com.cn/Info/productdeta ... t-overveiw
Manual in the attachment.
Is there an quick way to create an 2(or more) shutter channel fixture?
The easy way is to create a 4ch dimmer and go with it or create 2 led par per fixture and use the groups, but I really love FS the easy and fancy way with the windows. So I can just quickly push a few buttons on the screen and go with it.
Best regards. :fs:
EYEFLASH 2 WW User Manual A Version.pdf
(1.53 MiB) Downloaded 17 times
Re: 3 dimmers + a strobe chanel
In that scenario you just use the custom sliders feature in Fixture creator, then you'll have a window with three labelled sliders for each dimmer and a strobe one in the usual place
Schuim
Post by Schuim »
Yeah I guessed it would be in one of these ways.
The fixture channeling is kinda exotic but it might be good to have a function build in for multiple shutters/dimmers per fixture in the feature.
Thx for the quick reply.
Will post a request for it :)
