Bezier shapes disappeared Topic is solved
Share your shape files and discuss this feature here!
Dpappas
FreeStyler Version: 3.6.43
Post by Dpappas »
Hello,
Im using 3.6.43 and my bezier shapes disappeared. All i have is a rectangle.. the twist, Flower and eight are not there anymore. Can someone help me out please?
Thank you
Re: Bezier shapes disappeared
That's an old version, when and how did you lose them?
Dpappas
Post by Dpappas »
Ive had it forever and it never caused me an issue..I downloaded the latest software and then the new one would not work with my fixtures or interface,, so I restarted my laptop from an earlier times to get it back. ever since then all it shows is a rectangle shape and nothing more. Ive always stuck with the saying if its not broke don't fix it,, and every time I do something like this it always bits me in the butt.
Ah, fyi you can now download old versions from the dmx wiki the link is on the main forum page, no need to revert your laptop because you lose everything up until that point. I use Microsoft OneDrive you could theoretically install FreeStyler in a folder synced to OneDrive then you'll never lose anything!
Return to “Bezier Shapes”
