sound to light in Cue
UTerror
Post by UTerror »
Hi all!
I want to use freestyler to control my lights, but I'm having some problems.
I tried freestyler 2.96j first, but I couldn't get the sound to light thing to work. It just didn't do anything. I could see the bar moving, so there was sound, but none of my lights did anything. (tested on 2 pc's)
Then I found 2.99c and that version does work! When I use the sound to light and select the LED pars they change color like they should. (had to make my own fixture, but it works)
Now I want to be able to enable/disable the sound to light during the show. I was looking at the cue list and found a button "react to sound" next to each sequence.
When I leave the 'sound to light' on @ the fixtures, it keeps on flashing all the time.
When I disable the sound to light and enable the react to light in the cue list, it doesn't do anything.
I just want to be able to play a sequence, stop or wait for a bit, let the lights react on sound, play another sequence, ....
Am I doing something wrong, or is that not possible?
(can some1 maybe send me an older version so I can test it?)
Re: sound to light in Cue
there are older versions at the botottom of the forum homepage.... if people sent me other versions i'll add them to the site
UTerror
Post by UTerror »
oh, I missed that.
Tested older versions, but it isn't doing what I want. Guess It isn't possible
aquas
Post by aquas »
Do you realy find a 2.99 version? I think that´s a miracle!!!! where you find that? I've asked for a new beta version and no one reply... I think that don't like me... :( lol
if you could help me i apreciate.
UTerror
Post by UTerror »
It's not that hard to find, but if they don't tell you then maybe you (or we) are not supposed to have it ;)
daantas
Post by daantas »
You must join the beta test team.
