I have a mini moving Head, wich has on a multi-functional channel the "whole" color-spectre (between vealues 8 - 231)
I´d like to realize a smooth color change, which demads a steady change (+1) within the vealues,
it should be like a sinus waveform (idealy back and forth between 8 and 231).
Is there a possibility to realize that?
Maybe with the Formula feature in the Fixture Creator?
the Support Site for the Formula Feature https://www.freestylersupport.com/wiki/ ... #operators doesn,t show operators to realize this,
maybe there are some "hidden" ones?
how to set up a "sinus-style" vealue-sequence for a channel
- Just started using FS
- FreeStyler Version: 4.1
- FreeStyler Version: 4.01
Re: how to set up a "sinus-style" vealue-sequence for a channel
the feature you are wanting does exist within the FX module within sequence creator. When you launch the sequence creator on the right side of the window you will see "FX" click on it and you will be rewarded with your wishes
