Controlling/operating Freestyler with Programm Change commands from DAW? How does it work?
trommlertom
FreeStyler Version: 4.1.1
I Use FreeStyler for: Band
Post by trommlertom »
Hello!
I have the following problem.
I want to control Freestyler with a DAW via "Proramm Change commands".
Freestyler does recognize the individual benches in the "Learn" function
--> 24 or28
However unfortunately, this information cannot be saved.
Only the type of command (CC176), the MIDI channel (1) and some weird MIDI note (32).
But this note I can't control from the DAW... :-(
The Bank commands on the other hand are recognized, but can't be saved.
Who has an idea?
The following information can be sent by my DAW (Studio One) via Loopbe:
Any idea? Any advice?
Thanks!
Thomas
trommlertom
Re: Freestyler per Programm Change Befehle steuern? Wie?
Gibt es wirklich keine lösung? 🤔
You may be wise to translate this into English as the majority are English speaking, if you consider it may be a big please report on English using the bug tracker (link in menu)
trommlertom
djSupport wrote: 15 May 2022, 15:37 You may be wise to translate this into English as the majority are English speaking, if you consider it may be a big please report on English using the bug tracker (link in menu)
Thanks for this advice!
trommlertom
Re: Controlling/operating Freestyler with Programm Change commands from DAW? How does it work?
No Advice?
Please help!
