Running Cues in Submasters Speed
perrip
- Commited FS Forum helper
- FreeStyler Version: 4.1.7
Hello, I have a quick question. I thought I had it figured out, but don't seem to. When I am running a cue in a submaster, and set the speed to lower than 100 percent, if I select a new cue via the submaster the speed goes back to 100 percent, is there a way to keep the speed the same? Thanks so much for any help with this
- FreeStyler Version: 4.01
Re: Running Cues in Submasters Speed
I believe in the cue window under the settings cog you can have it not reset
perrip
I thought so too, and I know I have done something in the past to make it work, I did not see it in the cog, and I just can not find a setting to keep the speed the same. Any other ideas?
cotdagoo
- FreeStyler Version: 3.6.50
Right clicking in a cuelist in the submasters theres an option - Leave speed "as is"
perrip
Thanks so much!!, I will give that a try.
