I have version 4.1.1 and i add fictures and i cannot change adress, and the problem seams to me to be from the lastest version of windows 10, cause i have another PC that runs older version of windows 10 and it works just fine.
When i change adress and close the program and reopen it puts the defaul adress back it doese not take the changes, and many more problems, when i move certin fictures it strobes randomly, fixters that work just finw with another pc and older version of windows 10.
Can somebody pach this please ?
Cannot pach fictures 4.1.1
- stropinel
- Just started using FS
- FreeStyler Version: 4.1.1
- djSupport
Re: Cannot pach fictures 4.1.1
If no one replies and you think it's a bug please report on the bug tracker
- FreeStyler Version: 4.01
is this an older installation upgraded to 4.1.1? 4.1 does not play well with files created in 3....
- stropinel
It is a Fresh install of 4.1.1 on a brand new pc.
#NoTechNoShow - www.notechno.show
I have 4.1.1 running on multiple PCs with no issues and no issues for the masses so it has to be something with that PC and or Freestyler install.
It may seem pointless but please list the steps you are taking to try and change the address of fixtures so that I may try to replicate and solve.
Make sure .net 3.5 is installed prior to installing Freestyler
djbastien
Do you solve the problem?
I have the same issue.
I run Freestyler 4.1.1 on W7 PC. It worked fine with the same PC and latest version but now I can't change addresses of my fixtures.
I have the same problem on a W10 PC with the FS backup from the other.
I just ran into this issue with 4.1.2 Win 10. Seems it is def a bug and needs to be reported
- stropinel
I did not solve the problem, i switch to older version 3, vorks just fine
