I have a problm, using a Eurolite 648/5 Led bar it's possible to change the groups of leds in the bar but, the fixture creator only permit to use 33 channels and the limit of the bar is 48. it's possible to separate groups of leds in the bar, so i want 8 groups that use 48 channels... at the moment i have change to 4 group, that use 24 channels, there is a way to use the full channels in the prog?....
Ok, i can use it anyway but i have another problm. when i'm using the pallet RGB.... is only possible to use 1 channel for Red and 1 for Green...etc. when i create the fixture the all groups can't be controlled by the pallet RGB, only the group selected. Is possible to change that in the prog? I use one fixture to one group of leds... imagine the number of fixture that i have in the screen... 6 bars...---> 4 groups of leds. it means 24 fixtures!!!! if i need to use the full groups....
