Lamp on 2nd address stays off
boothb
- FreeStyler Version: 4.1.1
So i am new here please be patient. I have created a moving head light. I have 2 of the same lights selected on the main screen. I have the start address one the first as "1". And "12" on the second. When i open freestyler and start one of my saved scenes both lights will pan and tilt like they should. light 1 the lamp comes on the second light will not. i have figured if i go to setup and remove the second fixture and then put it back in on same row (2) then it will work fine. Any idea why i have to unload then load it back in.
- djSupport
Re: Lamp on 2nd address stays off
Does the error reoccur now or is it fixed?
boothb
Still have the problem. not sure why the lamp will not come on my second fixture. Its a moving head fixture, with 11 channels. so i have the address on the second fixture to channel 12. it will pan and tilt ( chanels 1-4) . channel 8 is the lamp.
- djSupport
Hmmm not sure then...
boothb
Thanks for reply. the last 2 times i opened up freestyler it works just fine. Not sure if i changed something to fix it or not. Anyway will keep playing on. Thanks
- djSupport
No problem
