Hi you all,
I love freestyler....sound 2 light but.....
really I am looking every where.....
How and where can I program a midi key to a block of my led-bar with 8 blocks. each block has RGB. 24 channels ( starvile 24 ch ) It is so simple that I cannot find it between the 1000 posibilities. Just clean and only 8 midi keys to 8 led-block.
Have ledbar on screen ready....works with souns2light....and even with a sequence
I know ...midi control in setup.....midi device (korg nano pad 2) start.....learn.... but then ????
Can some one give me an advice ?
Marcel
simpel midi key to led block in led bar
Marcel22
- FreeStyler Version: x2
- FreeStyler Version: 4.01
Re: simpel midi key to led block in led bar
what is it that you want this Midi key to do? Turn light on? off? sound? strobe? If the action you are wanting requires multiple channels of the fixture you will need to build a sequence or macro then activate that via midi
