Help with midi rerunning sequences
rooooooodog
- FreeStyler Version: 3
I am needing some help figuring out why I can't re-trigger a sequence using midi. I can successfully trigger a sequence to run using a midi note but once the sequence runs it won't rerun again. Am I missing something simple to reset or re-trigger a sequence. If I go in and press the blue arrows next to the sequences they run as expected an unlimited amount of times.
tboedhram
- FreeStyler Version: 3.6.51
Re: Help with midi rerunning sequences
In the Midi setup, click on "Options" then check "Disable double trigger protection". This will let you trigger midi cues multiple times
