ISthere anyway to have prearranged movements like sunlite 2006 has i know freestyler has some movements but i was wondering if anyone has a big library of some already made thanks
John
pre made movements
- FreeStyler Version: 2.95G
- aquas
- LJ
- FreeStyler Version: 3.0.1
Re: pre made movements
Hello,
i think that you don't have lucky to find the pre-made movements that you want, but i'm sure that you can create more movements using the pre-made. you can change the positions of the points! Generate new movements, save and if you want to mix the movements that you build, open de sequence creator and put it on, generate scenes... and select another one... etc. you can create more and more!!!!!
