strobe reacting to masterintensity
doctorzorro
I Use FreeStyler for: Eurovision
Post by doctorzorro »
Hi all,
Would anyone know why my strobe channel is reacting to the master intensity? This happens when running submasters with disabled fades on the cuelist. I'm running rgbw fixtures with strobechannel and whatever I do, the strobe will go slower when I pull down the masterintensity. I've tried making a separate fixture for the strobechannel but it still reacts to the master even when I tell that fixture to ignore master intensity.
The whole fixture is built like a scan, so the strobe should not be affected by intensity. Even tried to put the strobe on a pan/tilt channel but it still goes slower when dimming. I can see in the output monitor that the strobe value is divided bij the intensity, no idea why.
Any help would be welcome, if it's a known bug or an unknown one, also let me know.
Regards,
11
Red lights are bad for ya, mmkay?
FreeStyler Version: 4.01
Re: strobe reacting to masterintensity
Post by Partyman »
Since this only seems to be affecting you (I see no other similar posts) It is most likely a file corruption or a setting somewhere. I would suggest a fresh install into a different directory and try with just that single fixture, no midi, touchscreens, or controllers and see if it works.
