Hi
I'm after buying one of the velleman interfaces, does anyone know which is the best one between the K8062 and the VM116?
...or what the difference is?
Velleman Interfaces
Snowcat
- FreeStyler Version: 3.2.1
Re: Velleman Interfaces
AFAIK they're one and the same (Somone will likely correct me though
Using a K8062 interface here (£50 from Maplins UK at the time, Kit build) and no complaints. Has been solid as a rock despite multiple teachers and form 4 drama classes trying to crash the thing.
Took me about an hour to solder everything neatly but otherwise a good little unit.
MarSafe
No correction, Snowcat, just an add-on
: The VM116 is pre-build, the K8062 is a kit. So the VM116 is probably a little more expensive.
Happy user for 2 years, never had a problem with my K8062. (6 6-channel scanners, 2 fourbars, a fogger and a switchpack)
